Récupérer le contenu d'une requete HTTP
  • Récupérer le contenu d'une requete HTTP
    Posté par jean sur 31 janvier 2025 at 9h58
    Je souhaiterais extraire (en gras souligné) les réponses du JSON issu d’une requête HTTP; ses données correspondent aux “nom de colonnes et valeurs” d’un classeur Excel à mettre à jour, dans l’étape suivante.
    Ci-dessous un exemple de la structure du fichier JSON :
    “status”:”ok”,
    “message”:””,
    “data”:{
    “id”:”2116″,
    “record_number”:”5″,
    “form_id”:”103″,
    “user_id”:”620″,
    “create_time”:”2025-01-06 09:19:35″,
    “update_time”:”2025-01-28 11:09:45″,
    “update_user_id”:”6330″,
    “update_answer_time”:”2025-01-28 12:09:45″,
    “start_time”:null,
    “end_time”:null,
    “direction”:null,
    “recipient_id”:null,
    “history”:”blabla”,
    “form_unique_id”:”5″,
    “origin_answer”:”web”,
    “answer_time”:”2025-01-06 10:19:25″,
    “user_name”:”blabla@mail.com (blabla)”,
    “last_name”:”bla”,
    “first_name”:”bla”,
    “phone”:”+330000000000″,
    “email”:”blabla@mail.com”,
    “update_user_name”:”blabla@mail.com (blabla)”,
    “recipient_name”:””,
    “parent_data_id”:null,
    “fields”:{
    “logo”:{
    “value”:”514383567448bebd02a0.png”,
    “type”:”fixed_image”,
    “hidden”:”false”,
    “time”:{
    “112514383567448bebd02a0.png”:””
    “date_et_heure1”:{
    “value”:”2025-01-06″,
    “type”:”datetime”,
    “subtype”:”date”,
    “hidden”:”true”,
    “time”:{
    “06/01/2025″:””
    “information_de_mise_a_jour_c”:{
    “value”:”Information de mise à jour (Changelog)”,
    “type”:”section”,
    “hidden”:”false”,
    “time”:{
    Le schema d’exemple :
    <pre class=”language-markup”>{
    "type": "object",
    "properties": {
    "status": {
    "type": "string"
    "message": {
    "type": "string"
    "data": {
    "type": "object",
    "properties": {
    "id": {
    "type": "string"
    "record_number": {
    "type": "string"
    "form_id": {
    "type": "string"
    "user_id": {
    "type": "string"
    "create_time": {
    "type": "string"
    "update_time": {
    "type": "string"
    "update_user_id": {
    "type": "string"
    "update_answer_time": {
    "type": "string"
    "start_time": {},
    "end_time": {},
    "direction": {},
    "recipient_id": {},
    "history": {
    "type": "string"
    "form_unique_id": {
    "type": "string"
    "origin_answer": {
    "type": "string"
    "answer_time": {
    "type": "string"
    "user_name": {
    "type": "string"
    "last_name": {
    "type": "string"
    "first_name": {
    "type": "string"
    "phone": {
    "type": "string"
    "email": {
    "type": "string"
    "login": {
    "type": "string"
    "update_user_name": {
    "type": "string"
    "recipient_name": {
    "type": "string"
    "parent_data_id": {},
    "fields": {
    "type": "object",
    "properties": {
    "logo_tiss": {
    "type": "object",
    "properties": {
    "value": {
    "type": "string"
    "type": {
    "type": "string"
    "hidden": {
    "type": "string"
    "time": {
    "type": "object",
    "properties": {
    "c100905_2024112514383567448bebd02a0.png": {
    "type": "string"
    "date_et_heure1": {
    "type": "object",
    "properties": {
    "value": {
    "type": "string"
    "type": {
    "type": "string"
    "subtype": {
    "type": "string"
    "hidden": {
    "type": "string"
    "time": {
    "type": "object",
    "properties": {
    "06/01/2025": {
    "type": "string"
    "information_de_mise_a_jour_c": {
    "type": "object",
    "properties": {
    "value": {
    "type": "string"
    "type": {
    "type": "string"
    "hidden": {
    "type": "string"
    "time": {
    "type": "object",
    "properties": {
    "type": "string"
    • This discussion was modified 3 months, 2 weeks ago by  Jean.
    DavidZed a répondu 3 months, 1 week ago 2 Membres · 1 Réponse
    6 février 2025 at 21h25
    Il suffit d’utiliser l’action analyser JSON (dans opérations de données) , tu pourras générer le schéma à l’aide de ton json d’exemple.
    Ensuite tu pourras appeller les valeurs souhaitées comme n’importe quelle valeur dynamique.
